Alfine non turn was...
[Closed] Alfine non turn washer Q's
[#6340113]
I'm having trouble building up an Alfine laden Cotic Escapade in that the chain is interfering with the end of the cassette joint (where the hear cable meets the hub).
Essentially, since upping my sprocket to 23t (flipped for better chain line) the angle of the cassette joint is no longer compatible with the chainline.
I'm currently using the green and blue anti turn washers and the cassette joint is pointing downwards at approx 30 degrees offset from the chain stay.
I'd like the have the cassette joint more or less parallel with the chain stay, so, which colour anti turn washers do I need?
I'm struggling to research a result, I'm guessing the 5l and 5r yellow and brown versions, can anyone confirm?
FYI the frame has horizontal dropouts. Backwards facing. That's track style, right?
Posted : 15/07/2014 12:01 am
Silver/White IIRC
Posted : 15/07/2014 12:04 am
Yes, silver/white I think.
Posted : 15/07/2014 12:05 am
Would be handy if that is the case as I'm fairly sure I've got a pair of those knocking around somewhere (don't currently have access to them to check)
Posted : 15/07/2014 12:06 am
I thought all "Retail" packaged Alfines came with them as standard (as well as the Blue/Green) so there's a pretty good chance you have.
Posted : 15/07/2014 12:09 am
