Hi. I have a kinesis decade h/tail, running a shimano Alfine rear hub. The chain keeps comming off which is a pita. I have adjusted the rear wheel to retension the chain, but it's not helped. Any solutions? Running a race facesingle ring up front.
cheers
Check chain line. Adjust by moving big ring to middle ring location (or vice versa) or getting a dished/flat rear sprocket.
Running a single ring up front, so how do I check the chain line?
Check by looking down the length of the chain, change by fitting ring either side of the spider.
Ok. Cheers chaps. 🙂
Of the sprockets with 3 tabs, see how some are flat and some dished:
http://www.sjscycles.co.uk/sprockets-hub-gear-dept631_pg1/
That might give you a neat solution.
All about chainline:
http://sheldonbrown.com/chainline.html
Cheers buddy. Much appreciated.
I had this problem until I discovered that the cog on an Alfine is a narrow one, designed for a 9 speed chain I think. If you are using a singlespeed chain, then it is not wide enough to hold it on. I now use Sturmey Archer cogs, such as this [url= http://www.ebay.co.uk/itm/Sturmey-Archer-Rear-Cog-Bike-Sprocket-13-14-15-16-17-18-19-20-21-22-Teeth-/171057907738?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item27d3d8881a ]click me[/url] and have no more problems.
