Anyone had this before , before i go investigating
Basically gf commuting day one versa came home today complaining of noisy gears
Its not been adjusted by her since i set it up
However it seems like the cable inner has got shorter ..... With shifter set with all cable released the shift arm at the hub is in gear number 2 no amount of adjusting the barrel adjusters gets it close
Obvious solution is to adjust the cable to suit but i know it hasnt been adjusted at all ( not even a puncture )so cant work out why its all to pot.
Anyone any ideas ?
couple of things to check, are the cable ferrules correctly seated in the shifter? and is the cable correctly routed at the hub end? it can get a bit mis-aligned and make a hash of shifting!
Might have been caused by someone messing with your bike whilst you were at work, had this once and found my front QR was undone!!!
She keeps it in a locked cupboard so im not concerned about that , its all bolt up anyway
Had a quick look and all seems in order except that the. Yellow lines will never line up 🙁
You sure you've not been "sleep tinkering"
Set up a video camera and see if you can catch yourself on film.
Nice try stu but ive been working in houston for the last fortnight !
Has the cable frayed and got caught on the outer stopping it returning to normal position. Just a thought
Il investigate tomorrow night she has to drive tomorrow anyway haha
Im buggered , spent all day trying tO resume order in the garden after 2 weeks workin away !
Mrs trail rat must have been "sleep tinkering" then. 😆
I've had outer cables that have had a few strands that stick out above the rest at the ends even though they were cut straight when fitted.
Take the end caps off and check that .
Stu can be the only explaination hub works as expected , shifter works
So either inner got shorter or outer got longer . Gah - i have no inners to hand 🙁
cut the outer down a half inch , refitted original cable - all works well .....
how odd !
