Alfine Di2 : opinio...
[Closed] Alfine Di2 : opinions / experiences?
[#5027779]
Anyone running this? Quite like the look, ive seen hubs for £160, lever £80 for 8 speed...
Posted : 03/04/2013 8:51 pm
Did'nt realise it was available yet (runs off to look on madison b2b)
Posted : 03/04/2013 9:08 pm
I really fancy giving one a go
Posted : 03/04/2013 9:31 pm
You need hub rrp £200,Lever £100 or £250 drop bar,motor unit £100 and battery+charger £120 (not sure but I suspect you'll need to buy a wiring harness for £100 as well).
Posted : 03/04/2013 9:39 pm
That starts to add up a bit....
Posted : 03/04/2013 9:59 pm
Yep. All of that, the hub must be the di2 hub. It's not possible to alter the standard 11 speed hub with the motor unit (even though this is available as a separate item) something about a return spring in one version and not in the other...
Posted : 03/04/2013 10:11 pm
Is the indicator unit optional?
Posted : 03/04/2013 11:13 pm
when do they launch mind control? I though the nice thing about the alfine was it had less exposed stuff to go wrong?
Does set-up not require the shimano software?
Posted : 03/04/2013 11:19 pm
£200 for the hub?? Try £400, at least that's what I was told for the 11sp anyway.
Posted : 03/04/2013 11:20 pm
I'm running an Alfine Di2 mark 2. It basically eliminates the issues with standard Di2. They upgraded to a cable so it won't run out of battery's. Seriously though, I'm all for progress, but a Di2 Alfine!!!!!! What's the point?
Posted : 03/04/2013 11:24 pm
SG-S505 Alfine Di2 internal hub gear, 8-speed, 32h, silver srp £199.99
My kung fu (and ctrl C) is strong.
Posted : 03/04/2013 11:30 pm
£200 8 Speed
£400 11 speed
[url= http://www.madison.co.uk/products.aspx?vertical=cycling&tier1=Groupsets&tier2=Shimano+Alfine+Di2+SEIS ]Here[/url]
Posted : 03/04/2013 11:42 pm
Who the **** asked you?......with yer.......FACTS!!!!!!! 👿
Posted : 03/04/2013 11:45 pm
Can anyone tell me the point of Alfine Di2?
Posted : 04/04/2013 6:18 pm
Why does it need a point?
It's just an option
Posted : 04/04/2013 7:24 pm
You're right, why would you want an improved product for your investment.
Posted : 04/04/2013 7:44 pm
They should stop the damn seals from leaking before adding electronics.
Posted : 05/04/2013 6:09 am
The price for that switch is crazy - £100 !!!
Posted : 05/04/2013 7:11 am
