Alfine 8 Speed Ques...
[Closed] Alfine 8 Speed Question
[#4181240]
Having problems slipping gears - how far from the cable stop should the 'nut' on the cable than slots into the hub be?
Posted : 20/07/2012 6:22 pm
I think it's 101mm but if you search on Google you should find the user guide as a badly scanned pic or a pdf.
The usual cause of slipping gears is a sticky cable or kink in the cable
Posted : 20/07/2012 6:30 pm
I'm having the same problems with my 11 speed.
To cure it you are ment to put it in 6th gear and alter the cable length to line up 2 yellow dots on the hub.
I've tried and tried so has my LBS it's going back very soon.
IMO internal hubs from Shimano are shite,,,,
Posted : 20/07/2012 9:09 pm
8 speed ones are really good, 11 speed ones aren't so good
Posted : 20/07/2012 9:57 pm
My 8 speed has been fantastic for 2 and 1/2 years with no maintenance.
The guys at the Shimano tent at 2010 MM24 said they'd not had a failure at all.
Have no knowledge of the 11 speed hub.
Posted : 20/07/2012 10:48 pm
