Alfine 8 gearing qu...
[Closed] Alfine 8 gearing question
[#8328713]
I have just bought a secondhand cotic roadrat and find the gearing a bit much ,I can't see that I would ever use the top gear's much especialy when ploding on cycle paths and bridleways. Currently it has a 45 tooth up front with what looks like a 20tooth sprocket at the back.
What are you guys running and on what sort of terrain are you riding
Posted : 03/02/2017 6:25 pm
32-18 for lake district equivalent.
44-45 is for on the road.
Posted : 03/02/2017 6:38 pm
My Saracen Pylon8 had the default 38T chainring and I think it was a default 20T sprocket (IIRC I bought an 18T spare but never got round to fitting it before I found a bad seat tube crack).
Typically it had 26x2" Landcruisers on it, 6th gear was good for flat terrain; 7th and 8th got me to a decent speed downhill; 3rd usually got me uphill (all on tarmac commute).
Posted : 03/02/2017 6:46 pm
I run 39-18 for the road mainly because I had an old road double kicking about when I built the bike. The range is roughly equivalent to a compact double with a 12-27 cassette, which is fine for round here. Obviously bigger jumps between gears though. When I used it on an offroad build it was 32-18 but tbh that was a bit tall for me.
Posted : 03/02/2017 7:24 pm
45/20 is standard road gearing for alfines. I used to run 32/16 on mine for commuting - that was a bit low. Easy on the hills but span out too soon. Currently running 41/16 but thats with an electric kit fitted so I don't need low gears for hills
Posted : 03/02/2017 7:53 pm
Rear sprockets are relatively cheap - but obviously would need a new chain if you go larger. I have a few if you want to try some. Nexus sprockets fit but have a couple of MM of dish - if yours is dished its actually a nexus sprocket. If you want to go huge on the rear sturmey archer sprokets fit if you file off 3 of the six tabs and come in huge sizes
Good gear calculater on sheldon brown IIRC - and the range is 300% in a alfine 8 which is equivalent to a 11-32 cassettee IIRC - a bit more range than a 12/27 I am fairly sure
Posted : 03/02/2017 7:57 pm
50t crank with 20t rear for me.
Allows for 16-17mph av on road on a pompetamine.
First gear is too high for anything steeper than 1:8 for me.
Top Max's out at 35ish.
Pick a ratio that allows you to spend most time in 5th which has the least drag (i think!)
Posted : 03/02/2017 8:56 pm
I had a ridgeback touring bike with alfine 8.
I found 42-20 was personally a great ratio. I could get up a 20% climb with that. I would top out around 22mph-25mph on the flat. (spinning like mad)
Posted : 03/02/2017 9:21 pm
