What size do I need? Any recommendations?
The guys at Sonder said an EC44/28.6 ZS44/40 was correct but I'm struggling to find something suitable..
Thanks in advance...
Im pretty sure all the Camino versions use the same drop-in bearings.
If you phone an alpkit shop, im pretty sure they have a pulldown on the computer that will let you buy a CC headset or FSA version.
Have you googled those bearing sizes with a bearing factor. Im sure a generic bearing of those dimensions would be fine.
I'm pretty sure my Camino is a V1 - kind of a Burgundy - non through axles etc.
Mine is a 44mm HT so running a tapered steerer I use an external 1.5'' Hope cup at the bottom and an inset 1 1/8'' up top.
Yup,I put a Hope mix and match set in mine.
The T47 BB on the latest frame was a bigger ambush #newstandards4all 😃
V1 here. I used a FSA orbit which has been faultless. I picked out the seals and filled the bearings with marine grease though. Don't know if it made any difference but its still smooth 3 or 4 years on.
Lesshaste, like this? 44 Id cups, 1.5 bottom - 1 1/8" top.
Is that a typo by the Sonder guy? The pick and mix ones appear to be zero stack ZS44 upper and EC44/40 like this? Nukeproof seem to be the same sizes too...
It's a NOS frameset so I don't have a headset fitted as a reference. Got it for a reasonable price and wanted to use my 700c QR wheels on something .
