Airshot tubeless in...
[Closed] Airshot tubeless inflator - great product
Twist it, don't yank! It's threaded. The proper tool is best, but you can do it with an adjustable spanner or pliers at a pinch if you're careful.
I've always used needle nosed pliers which mostly work, but are a faff and eventually knacker the threads and round off the flat bits... until the other day when I realised a spoke key will do the job MUCH easier. Why did nobody tell me ages ago?!
Posted : 25/06/2015 7:18 am
Tip of the week right there, Sir, I salute you!
Posted : 25/06/2015 7:34 am
I'm about to go tubeless so have ordered one. I hope it's good and this thread isn't part of an elaborate STW joke to trick the unaware.
Posted : 25/06/2015 9:27 am
How many packets of the special compressible air did you order to go with it?
Posted : 25/06/2015 9:44 am
I only use nitrogen with mine to give better tyre performance
Posted : 25/06/2015 10:33 am
I've ordered some helium to help me with jumps.
Posted : 25/06/2015 10:37 am
Spoke key is ideal for valve inners but the wee plastic doobries to remove/tighten them cost pretty much nothing so I got a pack of 10 off ebay for about 75p IIRC, just for convenience. In practice, I don't usually bother to remove though, it's not usually necessary.
Posted : 25/06/2015 10:38 am
Just got one of these, playing with the pressure to inflate
Do I just whack the max 160psi in and let it rip?
Got it from leisure lakes - 6% quidco
Posted : 06/09/2015 1:55 pm
Yip
Posted : 06/09/2015 5:21 pm
Have bought the Airshot. Tried the ghetto route but it failed when I needed it most (the day before a Scott Marathon). It took the wheels to my LBS and their compressor failed. After that I vowed never to leave it to chance so bought an Airshot. It's a good bit of kit... it takes any uncertainty out of tubeless.
Posted : 06/09/2015 9:00 pm
Just had one of those blue bottles delivered and it has worked as advertised. Straightforward and drama free seating of a Magic Mary and Hans Dampf on a Roval Fattie wheel set.
Brilliant piece of kit.
Posted : 09/12/2015 4:04 pm
jamj1974
I have just fitted the same tyres to my Roval Fatties, do you have any side to side wobble the the Magic Mary? I have about 5-7mm on mine?
Posted : 09/12/2015 5:15 pm
Mine seem OK tweedviper. Couple of mm only. Less than on a couple of recent Continental Rubber Queens I have had.
They were an absolute git to fit - hence the Airshot purchase. Had a couple of issues in the past with tubeless but generally tubeless has been trouble free but these were a real PITA.
Posted : 09/12/2015 5:42 pm
Hi jamj1974
What size are yours? as my 650b's were really easy to put on and I only used a Joe Blow track pump to inflate both of them which went fine first time, the only problem I have is that the Mary wobbles
Posted : 09/12/2015 6:37 pm
Have you followed the bead around the rim to make sure it's all correctly seated?
Posted : 09/12/2015 7:01 pm
legend - Member
Yes the bead is perfect all the way round, the rim tape appears to be perfect, the wheels are within 1mm of true, I have pumped them up to 50psi with plenty of lube on the beads, lbs said they may settle, I am not so sure but hey ho
Posted : 09/12/2015 7:23 pm
Really like my airshot only niggle is it doesn't stay stood up but otherwise it's perfect as I already have 2 x track pumps
Posted : 09/12/2015 7:33 pm
Hi jamj1974
Magic Mary is a 2.35 and the Hans Dampf is a 2.2 I think. Even when I have had trouble before my Joe Blow in the end has sorted it... Not this time.
Posted : 10/12/2015 12:39 am
Page 2 / 2
