Hi.
Have a Float CTD and was thinking I may need an volume kit.
This one
[url= http://www.mojostore.co.uk/acatalog/Air_Spring_Volume_Tuning_Kit.html ]null
Reason being that it goes through all its travel very easily.
However, doing a bit of research on my shock on the Fox website it says this
2014, FLOAT-A P-S, CTD BV LV, Norco, Sight C1/UK 7.0 A1/UK 7.0 C1, 7.875, 2.250, 0.4 Spacer, VTL, RTM, 250, 16
Which seems to say it has a 0.4 spacer already. Am I correct?
I originally setup sag at 25%. Then when I noticed the shock using up all travel I then set the pressure for my weight, about 96 kg ( can't remeber pressure off top of head) and this is about 20% sag. Still no change. Therefore looking for answers and arrived at the inserts.
Any knowledge appreciated.
Drop the pressure out of it, unscrew the can and have a look. Should be obvious if it's there.
Yes. will do that. If it is there I am thinking to try the next size up.Anyone done this?
I done this to the ctd shock on my trance. If it was in descend mode it would do most of its travel just bunny hopping up a kerb.
Whilst it made a bit of difference it still isn't perfect.
I've had to send mine off to mojo as its blown so I've asked them to custom tune it.
I did it a while ago, very simple and effective. Certainly physically easier than the same on a CCDBA, assuming the air can unscrews no bother.
Ok. Gonna do it. Anyone have any of the spare spare spacers for sale? Was thinking of the 0.6 spacer for a 2014 model. Rather than buy a complete kit. 😀
