After a rear shock ...
[Closed] After a rear shock to replace my Fox RP2
[#4391636]
Hi looking to replace my fox RP2 rear shock as it is 3 years old and seems to sometimes leak air.
It's 200mm eye to eye so I am assuming another RP2 or RP23 with the same measurements will be a straight swap??
Where can I get this new, seen a couple used on eBay but they are from different bikes (mines a zesty 514) will this make any difference?
Thanks
Posted : 23/09/2012 5:51 pm
Why not service it?
Posted : 23/09/2012 5:53 pm
Send it for a service
Loco tuning
Tf tuned
Posted : 23/09/2012 5:54 pm
Why replace it? You 'could' service the seals your self for £20ish (vids on utube), though I'd get a full service for it after 3years of use.
Posted : 23/09/2012 5:56 pm
Seen some RP23's go used for about £100 on eBay, how much roughly is a service ?
+1 for loco,ing it.
Problem solved and sent back to you better than new. 🙂
Posted : 23/09/2012 6:01 pm
£70 from loco tuning for service, may look into that!! Or try grab a used RP23 for about £100-120. Is heir much difference between the RP2 and RP23
Posted : 23/09/2012 6:03 pm
Not far off that when you include p&p tbh,but then yours already has the manufacturer recommended damping tune & air sleeve to match the bike. Added to that, no mater what the description, a year old used shock may well be as worn as your is.
Posted : 23/09/2012 6:06 pm
Yep.Right on the button there z1ppy.Yours is the right tune and a second hand one has unknown history and the wrong tune.So to end up with a reliable shock you,d end up paying twice.one for the shock and again for a service and re-tune from Si at loco. 😉
Posted : 23/09/2012 8:50 pm
