Advice: Spank Oozy ...
[Closed] Advice: Spank Oozy Trail 295 valves?
[#7292894]
Does anyone know if standard 32mm Stans Notubes valves will work in Spany Oozy trail 295 rims?
I cant see the recommended valves anywhere apart from CRC and they are out of stock there (Spank Valves for Tubeless Rim).
Posted : 27/08/2015 9:03 am
 Crag
Not sure about the Stans valves but can't imagine they wouldn't work.
I use these on mine
http://www.ebay.co.uk/itm/Mountain-Bike-Road-Bike-Presta-Tubeless-Valves-Blue-For-No-Tubes-conversion-/261983935520?hash=item3cff759c20
I'd have thought any tubeless valve would do the trick.
Posted : 27/08/2015 9:22 am
I have used standard round shaped ones in my Spank wheels and it seems to work fine with the Oohbah profile.
Posted : 27/08/2015 12:14 pm
My 35mm Superstar ones wouldn't fit a pair a mate of mine had built.
Got some of the longer Stans ones, which worked lovely.
Posted : 27/08/2015 1:03 pm
Thanks for a advice guys.
My stan's valves were 42mm after all and once i wrapped the rims twice round in tape, used a hot spike to pierce a hole for the valve and put some Vaseline on the valve they went up a treat just using a track pump.
Didn't even have to use suds or sealant 🙂
Posted : 27/08/2015 11:26 pm
