Advice - Shimano MT...
[Closed] Advice - Shimano MTB cassette on Road CX wheels ?
[#8229168]
OK...genesis Vagabond, shimano 10sp MTB groupset 11-36 MTB cassette
got some Pro-lite disc wheels ...700c / road CX
will the cassette fit as essentially its a road hub ..right ?
actually i have fitted it and the only issue is the hub is 11speed but has a additional spacer for use with 10 speed
sorted ? well not quite as when i use the spacer ( think its 2mm ) the cassette lock ring will not do up or engage with the threads ( just spins ) if i take the spacer off there is too much play
i have used a thinner spacer ( comes with Shimano road cassettes ) but question is the road free hub shallower than an MTB hub which is why the lock ring won't work with
Posted : 14/12/2016 11:35 pm
 P20
11spd mtb is the same width as 9/10/11. Road 11 is wider. So 11spd road won't fit mtb. 11spd mtb will fit with spacer on 11spd road hub
Posted : 14/12/2016 11:42 pm
thanks.. i have 10speed MTB cassette on an 11 speed road hub with a 10 speed spacer option....if that makes sense ?
Posted : 15/12/2016 1:36 am
That's it.
Posted : 15/12/2016 1:40 am
Unless I'm mistaken it's a 135mm hub required for that frame which is standard mtb width?
Are you putting a 130mm road hub in it?
Posted : 15/12/2016 4:38 am
assuming 135mm spacing not an issue - CX disc wheels most commonly 135 because until recently nothing else available?
I recently looked this up and was successful though you do need to jiggle the cassette and spacers a bit to get the lock nut engaged
for my 11speed hub (Kinesis branded) 10speed shimano 11-34
needs 2 spacers a 1.85mm which should come with the wheels or can buy reasonably easily plus a 1mm spacer which comes with the cassette
Posted : 15/12/2016 11:15 am
thanks all, no issues with spacing as def 135mm ( std disc hub )
I have put the 1mm which actually with lock ring really tight seems to hold the cassette with no play so hopefully fine.
was just a bit confused as to the why the spacer that came with the wheels ( specifically for the 10speed option ) was essentially too big and meant the cassette was too 'high' therefore the lock ring was unable to 'bite' on the hub thread...if that makes sense ??
Posted : 15/12/2016 2:07 pm
ahh, when you said road hub I assumed you meant 130mm.
so yes it's just putting in the correct sized spacer for the hub/cassette combo you are using as you've done.
Posted : 15/12/2016 2:45 pm
