Advice re Disc-Cali...
[Closed] Advice re Disc-Caliper setting
[#2371263]
oh SO annoying 🙄
[b]
Set up[/b]
Forks= Fox vanilla RC in VGC
Brakes = Hope mono mini double piston (not M4)
Rotor= Hope floating
The rear set up is just bog standard 160 rotor and runs perfectly, brake off with zero rubbing - buttery smooth & spins longer than a chief whip's BS!
The front has been a royal PITA! Upgraded the front from a 160 to a 202 hope rotor. Braking power was/is brills, but I couldn't stop the rubbing regardless of shimming. So, upgraded again to a hope floating as research seemed to suggest they eradicate this sort of problem.
[b]
The two methods I've used[/b]
A
1. Opened up pads (new ones) to seat pistons.
2. fit, align & part screw bolts in.
3. Apply brake and hold
4. fit shims.
5. Tighten.
result= rubbish, rubbing more than standard rotor
B
as above to 3.
4. Tighten bolts up.
Very tempted to bin the floating rotor for a meaty fixed, any suggestions?
Why should the rear be such a POP to set up, yet the front is so .....pernickerty???
Hugs & kisses
LT
Posted : 15/01/2011 6:36 pm
You need to follow the video on the hope site for best reults - Its a two stage process - centre the caliper on the disc and then centre the pistons in the caliper.
Are you sure both pistons are moving freely?
http://www.hopetech.com/page.aspx?itemID=SPG152
Posted : 15/01/2011 6:47 pm
