Advice please
[Closed] Advice please
[#9542289]
So my bike seems to chirp when I ride rock gardens, it seems like it's maybe something to do with the tires. It's quite loud but only at speed over rocks or similar terrains. Anyone had this before? Or know what it is, because I'm starting to think I got a bird trapped in my frame 🙄
Posted : 10/09/2017 10:00 pm
only time my bike chirped like a bird was when the dbair inline shock blew a seal.
Posted : 10/09/2017 11:50 pm
Could be anything...
Favourite non obvious squeaky culprit is the rear mech hanger. Clean and grease.
Posted : 10/09/2017 11:54 pm
Buy another bike for when you're on rock gardens. N+1 answers most maintenance issues...
Posted : 11/09/2017 7:10 am
 poly
If it's tire related changing the pressure will probably have an effect - not necessarily eliminate, but change the tone or make it more/less common. Easy enough thing to try at the trail side to rule it in / out.
Posted : 11/09/2017 8:48 am
rudedog, frost on your moustache?
Posted : 11/09/2017 8:49 am
What kind of bike is it? Full suspension? Could be the shock or fork as they have to work much harder (faster compressing etc) over rock gardens.
Posted : 11/09/2017 8:51 am
My DT forks chirp if I forget to unlock them before hitting anything larger than a pebble.
Posted : 11/09/2017 9:09 am
I have an intense tracer 2017 Running a Yari fork and monarch + R piggy back shock! High roller 2 tubeless rubber. Bike is like 5-6 rides old, it does feel a bit harsh at the bars to be fair would it be possible the fork isn't dialled right?? Or maybe the tubeless tires moving around?? I'm baffled
Posted : 11/09/2017 5:31 pm
