Hi all,
Is it necessary to let the air out of the post before flying or will it be ok as it is?
Nope - old wives tale nor do you need to take air out of anything else. I have reverb and been abroad twice, I just slam it all the way down. The cargo hull is preasuired!
Uses hydraulics anyway. Planes use hydraulics - go figure...
Heather Bash - Member
True, but plane hydraulics are designed for use at high altitude whereas hydraulic seat posts are not......
There's a slight increase in relative pressure when you put inflated stuff in the hold. When your fat arse lands on it from a botched tabletop there's a MASSIVE increase in pressure. It should handle the plane 🙂
depends if the plane is on a conveyor belt or not
