Advice needed - cha...
[Closed] Advice needed - changing XT triple to single
[#7541505]
Will I need shorter chainring bolts?
Thanks
Posted : 28/12/2015 5:08 pm
 mboy
Depends on the chainring you use... Normally, yes you will, but some rings, particularly the 30T 104BCD chainrings, are offset to avoid the chain rubbing on the chainring tabs, and actually require you to use the normal length chainring bolts.
Posted : 28/12/2015 5:13 pm
Quite a few single rings com with bolts now anyway.
The OneUp I just got for my xtr cranks came colour matched ones.
That said new bolts are pretty cheap.
Posted : 28/12/2015 5:20 pm
Shimano XT M8000 Will see what it's like when it turns up
Posted : 28/12/2015 5:34 pm
Having fitted one this morning I can tell you no standard bolts fit
Posted : 28/12/2015 5:49 pm
Thanks all - think I may have some short ones somewhere
Posted : 28/12/2015 7:14 pm
