Both in 2.25" (26")
to go on the back of my Latitude - mostly Peak district usage, but some woodsy stuff
Much difference?
Would the Advantage roll faster?
I went from 2.25 advantage front and rear to Smorg back and Chunky Monkey front and it was a big improvement in grip and rolled fine off road. Bit more draggy on road but you're doing it wrong if you're bothered about that.
I've not tried a smorg but the advantage makes for a good rear tyre. Good rolling and decent grip in dry and wettish. Also good volume esp in 2.25, and quite light. I found it does drag noticeable less than a baron & rubber queen on the back. I swap to a deeper tread / mud tyre in the winter/v wet.
Going to try a Hutchinson Toro next time, the 2.15 is small though.
Anyone tried the 2.35 does it have a bit more volume?
