Adjusting pad clear...
[Closed] Adjusting pad clearance on M775 XT brakes
[#803466]
Can it be done, fitted a new hose and bled em yesterday, now the back has very little clearance. How do i sort it?
Posted : 21/08/2009 10:44 am
(have never used shimano brakes but)
Don't most self-adjust as the pads wear? I'd open reservoir, force pasds/pistons a bit futher apart, [edit: then close off reservoir] then put rotor inbetween pads & squeeze.
Posted : 21/08/2009 10:50 am
they do self adjust but shimano have designed these for greater pad clearance
Posted : 21/08/2009 10:51 am
yeh, but I think that's just a feature of the cylinder/lever design - don't [u]think[/u] you can alter it
Posted : 21/08/2009 10:56 am
the front and rear are different, i have bled the rear, not the front. Have i over filled it?
Posted : 21/08/2009 10:58 am
squeeze the lever right to the bars a few times, if that doesnt sort it you may have put too much fluid in the resevoir, easily solved by squeezing the lever gently and opening the bleed nipple (cover it with a rag or bit of flexble hoze to stop the oild getting on the brake) to let a very small amount out.
Either that or just ride and it'll wear off enough for it to be a non issue.
Posted : 21/08/2009 11:00 am
not in 90 mins last night it didn't
Posted : 21/08/2009 11:04 am
that's my guess - or rather you've filled it with the pistons not fully back (same thing anyway)
pistons were held apart by the yellow bleeding block
Posted : 21/08/2009 11:21 am
suppose we're left with overfilled then
(unless...does the block go onto bare pistons or between pads? If between pads, did you use old worn ones & then put in new ones)
Posted : 21/08/2009 11:38 am
onto pistons
Posted : 21/08/2009 11:42 am
Maybe you just need to adjust the screws at the lever?
Posted : 21/08/2009 11:49 am
Overfilled is the diagnosis 🙂
Posted : 21/08/2009 11:54 am
drop the pads out and try to push the pistons back. If they go, it's not over filled, if they don't, open the nipple and push them back, then close the nipple. Wash down and replace pads.
Posted : 21/08/2009 12:04 pm
onza - just done what you said - all is now good. The piston on the nipple side was slightly proud so et some fluid out and all is now sorted. Thanks
Posted : 21/08/2009 2:12 pm
