I've got a medium Trek slash and the lockout lever on the shock fouls the bottle when in the lockout position. I've tried the fabric cageless bottle which was a big improvement on her a cage but still rubbed enough to finally split the bottle on last nights ride.
So does such product exist as a bottle cage mount offset or failing that an adjustable cage?
http://road.cc/content/review/215727-kinetic-twenty20-cage
I saw something else similar the other day, but have forgotten where! If I remember....
this ere what you probably want:
http://www.wildcatgear.co.uk/shop/accessories/mount-skidmore-bottle-cage-adapter/
I've used those mount Skidmore adapters. They work well
I've also used elite band-on bottle bosses. They are like very tough zip ties that fasten on with a screw to tension them. Good but probably not as firm as the MS ones.
I use one of these.
Just use the thin metal bit and ignore the plastic cover.
Think I'll give that d12 battery adapter a go, took quite low profile. Bit of a tart question but is the thin metal bit inside silver or black?
https://www.torqfitness.co.uk/acatalog/info_201.html
A compact 500ml bottle. Much smallet than a normal one. Use it with a Zee side loading cage
Themetal part isblack on my di2 battery holder.
I use the plastic bit tomake it look pimp.
