!!Aarrggghhhh I...
[Closed] !!Aarrggghhhh I've rounded a cleat bolt!!
[#1403525]
As the title suggests I've made an ar5e of taking a cleat bolt out and rounded it. How the **** am I gonna get it out now? Help! Please!
Posted : 11/03/2010 7:06 pm
commiserations is all i can give. feelin for ya buddy.
now get the drill out and mtfu.
Posted : 11/03/2010 7:11 pm
If the cleats are knackered, try and cut a groove in the head and turn it like a screw or drill the head off and use mole grips to extract the bolt stem.
Posted : 11/03/2010 7:12 pm
Carefully drill it out, cleat bolts are (as you've just found out) pretty soft, so it's an easy job.
Posted : 11/03/2010 7:21 pm
Thanks folks but you're both right....the only option now is to show it the drill....and todays fettling was going so well up until that point.
Posted : 11/03/2010 7:24 pm
Find the torq bit that is a bit too big, bang it in with a hammer and then use an battery drill to spin it out, simples.
Oh yeah plus gas or WD40 it first
Posted : 11/03/2010 7:25 pm
in a similar situation i used one of those reverse thread screw extractor drill bits. did the job (though i nearly broke my wrist in the process - be warned!).
Posted : 11/03/2010 7:40 pm
crikey @ the bendy wristed 🙄
Posted : 11/03/2010 7:46 pm
If the cleat's useless I use an angle grinder to cut a screwdriver slot. And it sometimes adds ventilation and drainage channels to the shoe.
Posted : 11/03/2010 7:51 pm
 Tim
Drill
and remember to spray a load of wd40 on it beforehand next time 🙂
Posted : 11/03/2010 10:28 pm
