Got the lock ring off and trying to push the inner drive off but its not moving any ideas?
Had the same problem. It can be quite stiff. Do you have a head from a socket-set that will fit into it? That helps.
And re-read their instructions in case you're just trying to push it out the wrong way.
Read and reread their instructions looks like socket time tomorrow!
Thinking about it again, I don't think I used the socket until the next section.
I think I just sat and pushed it really hard and eventually it dropped out. I might also have tapped it gently with a hammer and a flat bit of wood just to encourage it a bit.
That first time was just absurdly stiff.
Done but the bearing is well fubarred can not even see the bearing code anyone know the code?
If your stuck ask Tim at Sideways.
What size cog is it Rich.
I think they have different sized bearings depending on tooth size.
My 18t regular WI freewheel used a 40 x 52 x 7 MM.
[i]What size cog is it Rich.
I think they have different sized bearings depending on tooth size.[/i]
Its my man cog 16T!
Sorted 67082rs
Its my man cog 16T!
Is that to go with your 24t front chainring? 😆 😉
