A tube is a tube ri...
[Closed] A tube is a tube right?
[#2494640]
After puncturing 3 times@ Coed Brenin I had to borrow tubes(3) so its half term and I,ve **** all to do and I usually run tubeless (tyre was split).Would it be considered a not a done thing to give them tubes back patched up and not new ones.
Rich
Posted : 22/02/2011 2:08 pm
If they were new when they were given to you then no, replace with new. If they had been previously repaired then I'd say it's okay to repair and return.
Posted : 22/02/2011 2:10 pm
unless they're all covered in the remaining sealant from the tyre what gonefishin said.
Posted : 22/02/2011 2:12 pm
sorry but it would have to be new for me.
Posted : 22/02/2011 2:13 pm
As above but depends on your mates. Put the shoe on the other foot. If you gave out a new tube and got back some tube with a few patches on it would you be happy? Running tubeless should not mean that you do not carry a spare tube and a tyre patch as well by the sounds of it BTW.
With tubeless you do run the risk of thorns in the tyre quickly puncturing any tube you insert.
Posted : 22/02/2011 2:16 pm
I'd replace with equivalent new tubes, it's just the right thing to do even though it doesn't really make any difference (not sure I own any tubes without patches, maybe some of the DH ones)
Obviously you need some tubes of your own so you don't have to borrow them off mates anyway 😉
Posted : 22/02/2011 2:18 pm
I never use patched tubes anymore.
Replace like with like is the fair thing.
Posted : 22/02/2011 4:02 pm
