are you running gears, either triple or double ringed.
if you are, what front mech are you running please.
someone must be normal, and run gears. 😉
I ran a 28.6 mm normal band xtr on mine 😉
Do bikes have gears nowadays?
you'll be putting suspension forks on it next
he'll have to find some forks first 😉
in it's geared incarnation, a XT, kept niche by using an xt thumbshifter
1x9 it is then....................... 😉
what a set of trogladytes.............no gears 🙄 😆
I know XT & XTR work fine from personal use. I know of folks using SRAM successfully as well. Generally you want high clamp, bottom pull, 28.6mm. Some of the 'dual pull' designs have bits which may foul the rear tyre if using a large rear tyre. Don't forget you can move the EBB to optimise the position of the FD. Usually high or low in line with the seat tube works best.
I'm using a 2x9 setup on mine, with a double specific SLX front mech. 22/32 chainrings.
Had to move the EBB so that the BB was at the very highest position to avoid the mech cage hitting the chainstay though either larger chainrings or standard triple front mech may make that less of an issue.
