9spd Clutch mech?
[Closed] 9spd Clutch mech?
[#6676175]
This has probably been asked before, but will a 10spd clutch mech (such as SLX m675) work with a 1x9 drivetrain? Will be using a 9spd SLX shifter, and an 11-34t cassette.
Planning on buying a N/W ring and ditching my guide, but assuming that I'll be constantly losing my chain unless I upgrade the mech.
Posted : 01/12/2014 11:04 pm
it will work OK with a Sram 9 speed shifter but not a shimano
Posted : 01/12/2014 11:13 pm
Ran 1x9 for a good while with a n/w chainring,no guide,droped chain only once,rattling down Cutgate.just slightly less noisy with a clutch mech.
Posted : 01/12/2014 11:25 pm
You will need to buy a SRAM 9 speed shifter combined with a Shimano mech and use a 5mm spacer under the cable pick up (& a longer bolt). There's loads of threads on it. Do a search.
Posted : 02/12/2014 1:47 am
It's the chainring that does the heavy lifting rather than the mech... Better to have both mind
(more like 6mm spacer btw if you want to SRAM it... I should have a couple of these machined up somewhere but I may have lost them)
Posted : 02/12/2014 1:56 am
A 6mm spacer is working on my Sramano set up, I cut up a brake mount adapter to make it.
Posted : 02/12/2014 8:02 am
Cheers guys!
Posted : 04/12/2014 12:49 am
