Hello all
I am just about to get a Cotic escapade frame and forks. The forks have a 9mm thru bolt skewer.
Does anyone out there know if you can get a bolt up (hex, Allen ) 9mm thru axel?
https://www.cotic.co.uk/product/escapade
It will be a lock up in town bike and would feel safer if the front wheel wasn't quite as quick release as a quick release 9mm thru bolt.
I appreciate that thieves carry Allen keys, but psycogicaly I will feel better!
Have tried google/Google images but can't seem to find anything with a link.
Any help much appreciated.
Olly
[url= http://singletrackworld.com/forum/topic/hadley-100-x-9mm-thru-bolt-hope-pro-2-hub-9mm-adapters ]One for sale here on Singletrack[/url]
Thanks for the replies.
The escapade fork has closed ends. The bolt thru you linked to has a little bit jutting out of the nut. Guess could grind that off.
Any other options out there??
[s]DT Swiss RWS 9mm Skewer
http://www.chainreactioncycles.com/dt-swiss-rws-thru-bolt-alloy/rp-prod81162
Suprestar 9mm QR
http://www.superstarcomponents.com/en/ultralight-alloy-9mm-front-qr-through-axle.htm [/s]
Should have read the OP propperly first sorry
