96bcd cranks & ...
[Closed] 96bcd cranks & a 94bcd chainring
[#6255473]
Basically, would there be enough 'wiggle room' to fit a black spire 94bcd narrow wide ring to my 2014 shimano Deore compact triple 🙄 with it's 96bcd, maybe a tiny bit of filing on each hole?
Posted : 08/06/2014 10:39 pm
About 1mm of filing...
Never done it but I suspect you'd trash a good ring.
Posted : 08/06/2014 10:45 pm
So that's a no go?
Posted : 08/06/2014 10:47 pm
Any more input on this?
Posted : 09/06/2014 9:24 am
I think you'd find that, much as 2mm sounds like only a tiny bit, it'd look like a lot when you offered it up and by the time you'd filed the ring to fit it would be looking pretty sorry for itself. Plus, you'd have removed quite a lot of the contact area that carries the load from the cranks to the ring, there's quite a lot of force goes through that interface.
Posted : 09/06/2014 9:30 am
All sorted, normal BCD cranks have been purchased
Posted : 09/06/2014 12:03 pm
