If I wanted to change the fork and headset on my old '96 Lava Dome to a 1 1/8 threadless set up is it possible?
Yes, just need fork, headset and stem.
What's the current set up?
Current set up is all the standard stuff from '96, so quill stem, impact headset and project 2 forks.
nice 🙂 I had '95... miss that bike 🙁
Why are you wanting to go threadless? Sus forks?
[url= http://forums.bicycletutor.com/thread-3880.html ]Doesn't look like you can[/url]
[url= http://forums.bicycletutor.com/thread-5041.html ]Although...[/url]
You'll not be able to go 1.1/8" threadless, but you could go 1" threadless with new stem, headset and forks.
Even mt 1993 Dawes is 1 1/8 and they have never been at the forefront when it comes to technology
ignore me, they were indeed 1.1/8"... so yes, not a problem to do the conversion, assuming your buying new threadless forks, headset and stem.
That's what I was hoping. So a fork with a 1 1/8 steerer tube and something like a hope traditional headset should do the trick?
yep
Why not? Konas have been 1 1/8in since 1991 at least, they were in there right from the very beginning. I put a modern headset and 1 1/8in suspension fork in a mid 90s Hei Hei no problem at all. I can dig out pics if you don't believe me! 🙂
PeterPoddy - just because I'll be doing similar soon it would be nice to see those pics if it's not too much trouble?
Here you go, I've only got pics of it from when I sold it, but I had a Reba on there most of the time. That's a Judy (from when they were good) on there in e pic, but it's still 1 1/8in with a clamp on stem and aheadset
[url= http://farm3.staticflickr.com/2660/3996260868_4f838e077f_o.jp g" target="_blank">http://farm3.staticflickr.com/2660/3996260868_4f838e077f_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/peter_atkin/3996260868/ ]DSCF0103[/url] by [url= http://www.flickr.com/people/peter_atkin/ ]PeterPoddy[/url], on Flickr
Much obliged Peter, good work 😀
I converted a 95 fire mountain from 1-1/8th threaded to threadless. Knock out old headset, press in new one, simple...
Why not?
You missed my subsequent posts correcting myself. For some reason I had it in my head that my '05 one was 1"...
PP, that looks amazing. I recently bought a 94 cindercone frame and forks which I was planning to restore and convert to a singlespeed....then I found out the wheels I expected to use with it had seized solid so its ended up as more clutter in my box room 🙁
