9 speed clutch rear...
[Closed] 9 speed clutch rear mech
[#6374362]
Am I right in thinking that using any Sram 9 speed shifter with a shimano 10 speed rear clutch mech will shift correctly on my 9 speed shimano rear cassette?
I just want as cheap a way as possible to keep my chain on a little more often than not on my 2010 stumpjumper which doe not have ISCG tabs for a decent chain guide.
Thanks
Colin
Posted : 30/07/2014 2:01 pm
Does it have any ISCG tabs? If not you can use a spacer mount that replaces a BB Spacer.
Posted : 30/07/2014 2:03 pm
Combined with a c5.5mm spacer under the cable yes. It will shift alright.
Posted : 30/07/2014 2:14 pm
If you want to fire me your address, I've got a wee spacer I machined for my old bike that'll convert the shimano mech to run with the sram shifter, just needs a longer bolt and a washer
Posted : 30/07/2014 3:13 pm
