Does anyone know where I can get one of these,without paying for a complete Avid bleed kit,or paying £30 for a Stahlwil?
Ian
Can you not bend a cheapy one to shape?
Not really,it's to torque up an Elixir pipe into the lever.
Buy an 8mm ring spanner and grind part of the ring off?
I've always managed in just using a std 8mm flat spanner to do just this.
I know,but I keep crushing the compression fitting.
The Olive? Aren't you meant to crust it? Thats how it seals.
Crush the Olive! Might be a bit crunchy if you crusted it. 😳
just use one finger to tighten it then rather than a big handful of fat sausage fingers
you can get cheaper ones that Stahlwil (Stahlwil are v nice though)
cheaper
http://www.uktools.com/crowfoot-wrench-p-54631.html
but as most have said use you hand and be careful.
