819 rim - can you r...
[Closed] 819 rim - can you run it with normal tyres?
 hora
[#3029533]
819 is tubeless specific of course but my tyres ripped. Can I run a normal 2.35 tyre with tube or does the rim need tubeless tyres/risk the tyre not seating properly?
Does the 819 pinchflat tubes easily due to its profile?
Its this rim (disc/cassette already on) or swap over to a DT 5.1 rimmed-wheel. Plus hassle.
Posted : 08/08/2011 8:15 pm
All tubeless rims AFAIK can be run fine with tubes and normal tyres.
Posted : 08/08/2011 8:16 pm
yup they will woork fine but some tyres are a bugger to get on and off UST rims.......
Posted : 08/08/2011 8:21 pm
Works fine. You can even use normal tires without tubes (sometimes).
Posted : 08/08/2011 8:24 pm
 hora
3 ride old LUST maxxis and its torn a hole along the based of a knob 🙁
Posted : 08/08/2011 8:41 pm
not stitch and patchable to bodge till payday?
Posted : 08/08/2011 8:53 pm
That's good going for a LUST 🙂
Posted : 08/08/2011 9:06 pm
Are 717's tubeless compatible?
Posted : 08/08/2011 9:11 pm
I've run them tubeless with stans kit, they worked fine.
Posted : 08/08/2011 9:13 pm
 hora
I'm guessing I've no grounds for a replacement FOC? The carcass should be thicker and last longer no?
Posted : 08/08/2011 9:20 pm
