8000 Lumen Light ??...
[Closed] 8000 Lumen Light ???
[#9811925]
Hi all. I’m looking for a new helmet light and came across these apparently 8000 Lumen torches. I currently have a 900 Lumen version  and find 8000 a bit hard to imagine.
will this really be 8000 Lumen ? Or even anywhere near that ?
https://www.ebay.co.uk/i/312039674941?ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F1%252F710-215725-24755-0%252F16%253Fmpre%253Dhttps%25253A%25252F%25252Fwww.ebay.co.uk%25252Fi%25252F312039674941%2526itemid%253D312039674941%2526tag2%253D3%2526tag3%253D103%2526tag4%253D6064006841060%2526tag5%253D3%2526tag6%253D312039674941%2526tag7%253D0%2526srcrot%253D710-215725-24755-0%2526rvr_id%253D1430566343713
Posted : 02/02/2018 8:09 am
Drop a zero and you'll be closer.
Posted : 02/02/2018 8:15 am
 Yak
No chance
Posted : 02/02/2018 8:17 am
If you take the square root of 8000, that will give you the ball park actual number...
the theoretical max lumens of my hope R8+ is 4000lm. It’s measured at 3000lm due to it (and any light) not having a perfectly efficient system. It has 8 LEDs and a battery as big as my fist which lasts an hour on full power, then an hour at 50%. That has 1 LED and a battery the size of my pinky finger.
Your call...
Posted : 02/02/2018 8:38 am
This one is nearly 8000 lumens 🙂
The one in the link will be about 1000 absolute maximum..
Posted : 02/02/2018 8:55 am
The maximum theoretical lumen output of the XML-l2 in that torch is 1198 I think - according to the cree website. I suspect that would require a decent external pack to hit that figure too.
Should still be a bright torch but realistically if you get near 1000 lumens that would be a good effort.
Posted : 02/02/2018 9:00 am
And that battery won't be 4200 mah - I've got some expensive Panasonics that are 3400mah and that's about as big as you get.
Chinese Lumen - as said above, real lumens will be about 800 maximum.
Posted : 03/02/2018 1:56 pm
[URL= http://i199.photobucket.com/albums/aa46/amticoman/beamshots6seconds022.jp g" target="_blank">http://i199.photobucket.com/albums/aa46/amticoman/beamshots6seconds022.jp g"/> [/IMG][/URL]
if it does not look like this then it is not 8000 lupins
Posted : 03/02/2018 2:44 pm
Bloody hell, is that a bat that has been set on fire or a plane with a pilot you have just blinded in the sky to the left?
Posted : 03/02/2018 3:12 pm
I can't see any lupins there Trout....
Posted : 03/02/2018 3:18 pm
Jesus! Are you getting reflections back off the ground or is that just stuff starting to ignite?
Posted : 03/02/2018 3:20 pm
Flower power... 😂
Posted : 03/02/2018 3:29 pm
Ha Ha   its an old Beam shot from about 10 years ago   way too bright to be useful on the trail .
This is an 8000 lumen bastard ugly light I used at this years puffer
[URL= http://i199.photobucket.com/albums/aa46/amticoman/IMG_0582.jp g" target="_blank">http://i199.photobucket.com/albums/aa46/amticoman/IMG_0582.jp g"/> [/IMG][/URL]
no beam shots yet but was great fun on the 2 times I popped it onto full .  the rest of the time it was on very low .
power was from a Smudge 15 volt battery pack
Posted : 03/02/2018 3:32 pm
