8 speed XT cassette...
[Closed] 8 speed XT cassette issue
 JoeG
[#5729317]
This evening, I installed a Shimano XT (CS-M737) 8 speed cassette on an older (2005 ish) American Classic made hub. The cassette lockring was torqued to spec with a torque wrench. When I then put the wheel in the truing stand, the cassette wouldn't spin! 😯
Upon removing the cassette, I saw that there was a spacer attached to the inside of the cassette that has a sharp lip that interfered with the hub's pawl seal. 😥 I also have an 8 speed (CS-M900) XTR cassette as well which does not have the spacer.
But when I look parallel to the cogs, the XTR casssette's splined section ends flush with the big cog, while the XT's is offset a bit towards the smaller cogs. No doubt this is why there is a spacer.
Does anyone have any ideas what I can do to get this to work?
[img][url= http://farm6.staticflickr.com/5473/11095690415_55171c059e_c.jp g" target="_blank">http://farm6.staticflickr.com/5473/11095690415_55171c059e_c.jp g"/> [/img][/url] [url= http://www.flickr.com/photos/91439976@N02/11095690415/ ]DSCN1785[/url] by [url= http://www.flickr.com/people/91439976@N02/ ]Joe____[/url], on Flickr[/img] Rear of XT cassette showing the sharp lip
[img][url= http://farm8.staticflickr.com/7342/11095770536_d28b3e7889_c.jp g" target="_blank">http://farm8.staticflickr.com/7342/11095770536_d28b3e7889_c.jp g"/> [/img][/url] [url= http://www.flickr.com/photos/91439976@N02/11095770536/ ]DSCN1781[/url] by [url= http://www.flickr.com/people/91439976@N02/ ]Joe____[/url], on Flickr[/img] XT cassette (left) with spacer removed, XTR cassette with no spacer (right)
Posted : 28/11/2013 6:12 am
Can you turn the spacer around?
Posted : 28/11/2013 9:01 am
I seem to remember that 7 speed freehubs were narrower than 8 speed (or was it the other way round? ) and spacers were needed if fitting a 7 to an 8.
Posted : 28/11/2013 9:14 am
Correct. 8/9 are the same width.
Posted : 28/11/2013 9:24 am
 JoeG
shermer75 - Member
No. Well, I can but it has the same problem reversed.
Posted : 28/11/2013 5:32 pm
I'd use a 'normal' spacer from an chopped up old cassette or single speed conversion kit to give the same clearance.
Does seem odd - Shimano are usually fairly 'universal' with stuff like this.
Posted : 28/11/2013 5:36 pm
I had a similar problem on a King hub. XT cassette needed a spacer, XTR didn't IIRC.
Quite odd.
Posted : 28/11/2013 6:09 pm
Ah yes, 8-speed XT cassettes, bloody awful things, only really good for scrap, although now you don't need it could I have it for the bike parts sculpture I'm making? Obviously I'll pay the postage. 😀
Posted : 28/11/2013 8:35 pm
