780mm+ bars, low ri...
[Closed] 780mm+ bars, low rise or even flat, decent backsweep.
[#8264402]
I'm currently running flat, 12deg backsweep Syntace Vector carbons in 760mm, which are ace but I fancy something a tad wider.
However, flat bars in >760 are rare, so I'm probably looking at low rise risers, say 10-15mm, and if I get a 8deg backsweep/4deg rise and run the bar 'flat' then I'll be close to my current 12deg, if I understand the angles correctly...
So, what do you reckon? [budget £100, 31.8mm]
Spank Vibrocore (800 Race) get good reviews and can be had at 15mm rise. Not as light as carbon though.
Answer Protaper 780 SL are 13mm rise at £95
http://www.chainreactioncycles.com/answer-pro-taper-sl-780-carbon-bar/rp-prod115839
Syntace Vector carbons do come in 780 but you have to go to 20mm rise...
Raceface offer the SIXC carbon at 785mm and 19mm rise:
http://www.chainreactioncycles.com/race-face-sixc-carbon-riser-bar/rp-prod106584
Any other options/opinions?
Posted : 01/01/2017 5:35 pm
 br
On One carbon, I've the soft 747's on my HT and the harder 777's on my FS. The harder ones aren't as stiff as the Renthal carbons I had on it, and better for it.
Only £60 too.
Posted : 01/01/2017 5:40 pm
Renthal Fatbars are 780 & can be had in 10mm rise.
Posted : 01/01/2017 5:44 pm
I've got a set of RSP carbon bars on both my bikes and really rate them (previously had easton havoc 750mm bars). 780mm wide,15mm rise, 9 degree backsweep and 4 degree up. You can pick up the RSP's for under £50 if you use the tredz £5 voucher http://www.tredz.co.uk/.RSP-Carbon-Ego-DH-Riser-Handlebars_92055.htm
Posted : 01/01/2017 6:08 pm
dougieb +1. I have the RSPs on my main bike which I got in a sale for about £32 IIRC. They are excellent and I wish I'd bought two now.
Posted : 01/01/2017 6:47 pm
cheers
Posted : 01/01/2017 10:12 pm
I will relieve you of your Syntaces if you've finished with them 🙂
Posted : 01/01/2017 10:21 pm
Great bars. I'm almost tempted to run the grips 10mm further out on each side so I can keep them...
Posted : 01/01/2017 10:53 pm
I've got the RSP ones,which are fine but I miss the shape of my old Sunline V1 762's (but not the weight or girder like flex).
Posted : 01/01/2017 11:13 pm
The Renthals mentioned above are very flat indeed - for risers. I have been running them for 2 years and don't find them too high or too stiff.
Posted : 01/01/2017 11:21 pm
If you're using double clamp lock-ons and keep your hands within the rubber area, not over the outer collar, then going to something like DMR Deathgrips could give you 10-20mm extra effective width. They add 5mm on each side to my bars and because there is only an inner collar I can have my hands right on the edge of them.
Posted : 01/01/2017 11:33 pm
 Jerm
A cheaper option is to buy some Santa Cruz Palmdale grips which add 25mm to the overall length
Posted : 02/01/2017 10:42 pm
update...
I've just made some acrylic bar ends on the lathe which add 10mm to each side, and fitted some single-lockon grips. Sorted.
Posted : 02/01/2017 11:15 pm
