750 wide bars: 9° v...
[Closed] 750 wide bars: 9° vs 6°......
[#6934946]
Hello one & all.
I've just sold my bars which had a 9° bend / 5° upsweep.
I've bought ones with a 6° bend / 4° upsweep.
Cockpit reach wise how much difference in mm will this make please.
Many thanks,
Alan.
Posted : 16/03/2015 8:43 am
I'm sure somebody will be out with a formula shortly but as you have sold the old ones and bought the new ones, does it matter? Fir them and set seat and rotation etc. to suit.
Posted : 16/03/2015 8:49 am
use a tape measure?
Posted : 16/03/2015 10:12 am
somewhere between **** all and next to **** all.
Why did you change your sweep preference would be a better question.
Posted : 16/03/2015 10:36 am
20mm tops. What angle you rotate them to in the stem will make most difference to you.
Posted : 16/03/2015 11:52 am
by eye it looks about 20mm at teh tips between my renthals and nukeproofs. its definately noticeable with teh 2 bikes side by side.
it would vary though depending on how far you roll forward/back etc.
Posted : 16/03/2015 11:53 am
Thanks all.
I was running Easton Havoc carbon bars with a 70mm Easton Haven stem & it felt spot on reach wise, but too high front end.
That's when I started looking for a wide flat bar or one with less rise.
I chose the Thomson Trail Carbon bars as the replacements.
The reason for posting this thread is I'm wondering if I will need to revert back to my 55mm stem before selling it, which it sounds like I will.
70mm Easton Haven stem FS shortly.....
Posted : 16/03/2015 2:27 pm
Bar backsweep makes a big difference to how steering feels - which should be no surprise as changing from a 70mm to 50mm stem is considered significant. A 4 deg change in backsweep equates to a 20mm change in stem length on typical bar.
Posted : 16/03/2015 4:26 pm
