73mm road chainset
[Closed] 73mm road chainset
[#8396302]
I have a genesis vagabond that has a 68mm shell but does have the clearance to run a road chainset I have an old mtb chainset running trekking rings but would like a compact chainset any ideas I'm assuming spare taper or middleburns would work any recommendations
Thanks in advance
Posted : 12/03/2017 11:57 pm
Square taper will work with the right BB length.
What are your requirements/problems?
I'd go external BB triple or MTB compact double with a closer ratio rear cassette above a road compact. Few can spin out a 50-11 top gear, but most will crave/need Smaller than a 34T ring when climbing...
Posted : 13/03/2017 1:26 pm
esky123 email sent.
Posted : 13/03/2017 1:31 pm
I have been running a MTB trekking chainset but taken off the little ring on the chainset running a 36-48 would like a a 34 - 50 would give me a decent range have been running it on a 11-28 and rode up everything I have attempted.
I am thinking of have a 11:32 cassette with 34:50 that would get me almost everywhere I would like to go I would imagine
Posted : 13/03/2017 4:39 pm
If I were you I'd just put the granny ring back on rather than buy a wider spaced cassette.
You surely don't need a gear higher than 48-11? so why bother with the expense and hassle of a new 34/50 chain set?
Posted : 14/03/2017 10:11 am
My original plan was to go to ultegra but it didn't work with the chainset when I had the bike it had bar end shifters that I didn't like so changed to r685s that only run a double and not a triple chainset. So it I changed back would have to get new stis and brakes which will cost just as much
Posted : 14/03/2017 3:00 pm
Ok starting to make sense. If you've got to go double due to your shifter... Why not put your granny back on, I assume a 26 or 24 tooth, plus a 36/38/40 in the middle position and leave out the big ring? A 40-11 is still a pretty fast gear, then you've got the granny for climbing. May need to adjust chain line slightly though
Posted : 16/03/2017 1:27 am
