700c wheels in a 29...
[Closed] 700c wheels in a 29er frame?
[#2378010]
Would 700c road wheels fit straight into a 29er frame. Don't worry I'm not building one but a mate was asking............
Posted : 17/01/2011 9:41 pm
Same difference diameter wise. You might find a rear road hub is narrower.
Posted : 17/01/2011 9:42 pm
Yes, although if it is a proper road wheel set it might be 130mm spaced.
Posted : 17/01/2011 9:43 pm
Why not just fit 700c tyres on the 29er rim?
Posted : 17/01/2011 10:06 pm
Rim bed might be a bit wide, depending on the tyre.
Andy
Posted : 17/01/2011 10:22 pm
ratherbeintobago - Member
Andy
Any particular ones? Kenda Small Block 8?
Posted : 17/01/2011 10:51 pm
Yes and no; it depends on the rim bed & tyre widths. There is a thing about it [url= http://www.sheldonbrown.com/tire-sizing.html#width ]here[/url]; a 38-622 SB8 should probably seat OK on a 17mm bed C29ssmax, for example.
Andy
Posted : 18/01/2011 4:53 pm
can put a cross tyres on a 19mm (internal) rim but i wouldn't put a 25c roadtyre on it.
HTH.
Posted : 18/01/2011 5:47 pm
The reason for asking my mate has some quite wide rimmed 700c wheels and the chance of buying a Surly Karate
Posted : 18/01/2011 9:07 pm
