I have an old touring road bike for repair. It is fitted with STI 105 3x7 shifters which are not shifting at all, tried lubing and new cables concluded that I need to replace them ,any suggestions where I might get similar. (in stock)
Thanks
Richard
fleabay? Won't 8speed ones also work with the mech limit screw set correctly?
Yes on ebay is if I get a retro set they might have the same issue. Yes 8 spd is an option too.
i've got a new in the box 8speed 2300/sora set
How much would you want for it.
Richard
what's up with the 105's?
normal failure mode for those shifters is that the factory grease hardens over time and makes the ratchet pawls stick and won't engage.
A *good* flush with a solvent/degreaser and manual wiggling of the pawls before regreasing normally sorts them.
A mate had a set rebuilt by a man in the states
let me know if you need to know more
They owe me £55, so £55 to your door.
Stoner cheers they were oos when I checked before! Just got an email from sjs confirming they are back in. Thanks
Tried to lube/soak them for a couple of days. The pawls for.the rear shifter are completely gone.time might be a factor if I need to get them rebuilt.
Sp thanks I will get in touch with owner and let you know tmrw.
Thanks for the advice appreciated
Richard
