Folks, i cant remember what spacers i need each side to install a HT2 BB on a 68mm shell. Anyone advise please?
1 on drive side, 2 on non drive side
HTH
Er, the otherway round surely? 2 drive side 1 non drive on a 68mm shell.
Either will work, but its usually 2 driveside, 1 non driveside.
yep, my bad... 2 on drive 1 on non drive is the norm
as bigyinn says, either works, but it will affect chainline, I have my spacer (73mm shell) on non-drive currently as running 1x9...
this should cover it...
bike.shimano.com.sg/.../Hollowtech%20II%20Crank%20Installation.pdf
Just incase you have an E type BB mounted front mech
I fitted one yesterday and it was 3 on the drive side and one on the non drive side.
Unless you have a mech mounted or chain device.
that just wrong. you only get 3 in the packet.
its two driveside, one the other side
With 4 spacers fitted check the crank splines are engaged properly
2 on both sides for me but thats only because the old BB exploded abd shaved a few mm off the non drive side. but it should be 2 drive and 1 non.
Cheers all, 2 on driveside, 1 nondriveside it is. Moochas Grassyarse.
