6802 2RS Bearing
[Closed] 6802 2RS Bearing
[#10387983]
Looking to replace the 6802 2RS Bearing in my resynolds road wheels.
Loads available so what ABEC3 or higher with low friction seals would you reccomend - that aren’t enduro.
I need to order these online so any suggestions for supply would also help.
Thanks
Posted : 13/12/2018 8:16 pm
If you want to geek out on bearing tech check out Hambini on YouTube. I think he concluded that the NTN ones were best for consistency (measurements) and low friction (especially as they have metal cages rather than plastic) with SKF and FAG close behind. The main advice was to buy a named brand from a known source (to avoid fakes).
Posted : 13/12/2018 10:04 pm
