68 / 73mm BB advice
[Closed] 68 / 73mm BB advice
[#3770254]
Is it ok to use a 68mm external (hollowtech II) BB in a 73mm shell?
Thanks
Posted : 13/03/2012 9:37 pm
yep, but use 2 spacers on the driveside and one on the non-driveside
Posted : 13/03/2012 9:38 pm
Yep, but ignore the advice above and use one spacer.
Posted : 13/03/2012 9:40 pm
Which side for the spacer?
Posted : 13/03/2012 9:42 pm
drive side 1 spacer
Posted : 13/03/2012 9:44 pm
Excuse my ignorance but if I don't ask I'll never know. How does a 68mm fit in a 73mm shell, it'll be too small?
Posted : 13/03/2012 9:45 pm
Yup, getonyourbike has it the wrong way round.
AndrewJ - Member
External BBs don't really have a width- they're 2 seperate bearing cups. The cranks are 73mm, so you use the BBs plus spacers to bring the BB shell up to size.
Doh! Me being simple... 😳 Don't know why I said that when I just rebuilt my hardtial and bouncer the other week. 68 and 73mm BBs respectively.
Where's the hammer to the head smiley when you need one? 😆 🙄
Surely the crank must actually be 75.5mm if you still have to run one spacer in a 73mm BB?
Posted : 13/03/2012 9:50 pm
That sounds like it might actually be right. In my defence it does not matter at all 😉
Posted : 13/03/2012 9:51 pm
Northwind - Member
Where as running 3 spacers in a 73mm BB might have. 😳 😆
Posted : 13/03/2012 9:52 pm
Thanks for that 🙂
Posted : 13/03/2012 9:59 pm
What about the plastic tube, that will be 5mm shorter, do you still use the tube?
Posted : 13/03/2012 10:29 pm
yup, still use the tube because of the spacers, the BB cups are still sitting the same distance away from each other so the tube will still work. Making sense?
Posted : 13/03/2012 10:31 pm
If you put a 68 BB into a 73 wide shell with a spacer isnt the tube going to be a little further away from the cups? A small detail I guess but curious.
Posted : 13/03/2012 10:54 pm
It's not a 68mm BB- what you have, is either a 68 shell with 3 spacers, or a 73 shell with 1. The 2 extra spacers that you use with your 68mm shell make it the same width for either option.
Posted : 14/03/2012 1:09 am
Just to add to the confusion. The road bike cups are sold as just 68mm with no spacers and have a shorter tube in the middle. But you don't need the tube anyway
Posted : 14/03/2012 9:41 am
Perfect, thanks all.
Posted : 14/03/2012 10:59 am
To add to this, I use 83mm cups in a 73mm BB shell. Shimano M815 Saint cups.
Plenty of extra thread to support the BB mounted chain device on the drive side.
Posted : 14/03/2012 12:18 pm
