661 Filter/Shimano ...
[Closed] 661 Filter/Shimano m424 - clipping in issues!!
[#3381190]
can't get the shoes to clip into the friggin' pedals and its driving me mad. ive cut some extra rubber away, but still no joy....
anyone else had this problem? if so did you manage to fix it?
and if not, then what pedals do you run with your 661 Filters?
ta
Ben
Posted : 23/11/2011 10:14 am
you could try spacing the cleat away from the sole a bit more so it's not as recessed - Crank Bros cleats come with spacers to do that.
Posted : 23/11/2011 10:21 am
do you mean under the cleat itself?
Posted : 23/11/2011 10:56 am
yes
Posted : 23/11/2011 10:58 am
wot he sed ^
Posted : 23/11/2011 11:00 am
ah right, so do people bodge shims, or can you buy them? just had a quick google and i'm not sure what i'm after!
Posted : 23/11/2011 11:07 am
I suse these with all my CB pedals at it stops the shoe gettign worn;
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=25138 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=25138[/url]
but it's not that thick - if you look the CB cleats come with plastic spacers too.
but for trial and error purposes you could just cut some spacers out of a coke can to find how much thickness you need and if it does solve the problem
Posted : 23/11/2011 11:11 am
can you use the crank bros shim with shimano cleats??
Posted : 23/11/2011 11:12 am
