650b rigid fork.
[Closed] 650b rigid fork.
[#5465066]
Any ideas. Its to go on a identiti aka. Fit for 26" and 650b, fancy going 650b with a rigid flavour.
Any ideas what fork would be good, would 29er rigid suit?
Thanks
Sam
Posted : 29/08/2013 10:28 am
It's more a question of how much axle to crown length (with suitable offset) you require for a given frame design, than a specific 26/27.5/29er fork.
Posted : 29/08/2013 11:01 am
I've had a 26er 2.5 in both of mine (Hylix and Exotic) with bags of room to spare... So other'n possibly a wee bit of extra height it shouldn't be an issue with most.
Posted : 29/08/2013 11:15 am
I'm looking at an axle to crown of about 500- 520 I rekon.
Although I'm not entirely sure
Posted : 29/08/2013 11:17 am
Is that the unsagged fork length? You want a bit shorter than that.
Long-travel 26er = 470mm rigid
Posted : 29/08/2013 11:35 am
29er forks in the main rigid are 470 to 490mm axle to steerer length.
Posted : 29/08/2013 1:47 pm
nice work guys, think i'll get me some 29er forks then as the frame is best suited to run a 26" fork @ 130mm travel
Posted : 29/08/2013 2:00 pm
Most 26" rigid forks will have room for a 650b wheel and tyre - why not just get one of those?
You'll already have a slightly larger diameter wheel without increasing the a-c on the fork by fitting something designed to solve a different problem - you'll end up with a much taller front end.
Posted : 29/08/2013 2:04 pm
Ah, so you think I could get away with running a 26" fork such as a exotic carbon.
I was worried whether this would affect the geometry of the frame too much
Posted : 29/08/2013 5:28 pm
