I'd quite like to get a 'proper', lighter b+ frame and (rigid) fork. One option is a direct from China one (I've bought direct before) but it's got Boost fittings and I really want:
- Clearance for 650b+ 3.0 tyres and ideally 29er ones too (though not big 29er ones)
- 'Standard' hub design - ie QR/15mm/20mm at the front and ideally QR at the back though non-Boost through axles could be considered.
- Probably aluminium (or carbon though that's going to be China then) - my Swift is great but with the B+ wheels, it's not particularly light
- Gear hanger
- Available in XL or at least with a 25"+ top tube
- £400 ish for frame/fork
So, what's out there? I suspect for the price, not much...
Only available as a full build, but this ticks all other boxes;
[url= http://www.hargrovescycles.co.uk/bikes/mountain-bikes/charge-cooker-1-2016-mountain-bike.html ]Charge Cooker 1 Midi[/url]
[IMG]
[/IMG]
I've got one of those and really like it. The QR was a bonus for me as I can swap in a set of 29er wheels I already had. Well worth £800 I'd say (although mine's on bike to work).
Any other suggestions?
Sonder Transmitter?
siwhite
Sonder Transmitter?
Which would be perfect were it not boost, thru-axled and doesn't take a 29er wheel. 😉
I ride a 10 year old Cannondale, and I'm not even sure I know what Boost is. Just trying to help....
If you want to run a 3" tyre in the rear with gears you might struggle with chain rub unless you go Boost.
Good point. TBH I've been pretty happy with my 2.8 tyres on relatively narrow rims so I don't think it's going to be an issue though.
Jameso, when is that coming out?! 😯
Prices and spec options? Was going to buy a Ramin as a hack, but would like to wait for a B+ option.
I wasn't aware that was the reason for boost, I thought Trek invented it to allow stiffer wheels, hence the wider hub she'll, that meant the chainline having to move out by 3mm on the drive side. This in turn ment short chainstays and big tyres clearance was also a benefit.
Didn't think you'd get chain rub with 142x12 rear with a none boost chainline with 3 inch tyres? Hence why that Pinancle still works.
Depends.
Is it "really" a 3" tyre?
What width is the rim?
Are you running only 1x up front?
Like the Pinacale above which is 1x up front and appears to have proper 3.0 WTB Bridger tyres. Can't see the rims but I'd want to run 45mm scrapers
Funny, I've been googling around for the same thing, tho would also pay up for (budget) Ti if it was out there. What Chinese option were you looking at nemesis?
Pinnacle's got a 2.8 Trailblazer on the back, Bridger up front. Rims are Scraper I45s. There's room for a 3.0 at the back but it gets tighter and a double would mean the chain's a bit too close to the tyre. Works fine for 1x and keeps the wheelset x-compatible with more 29ers currently out there. I guess it'll go Boost in future but for now, didn't see a strong reason for it at this RRP level where it's meant as a cheaper way in to B+ or a try-out and a winter 29er project base, a simple bikepacker etc.
Hooter - something like this though from Miracle Bike as I've been happy with my previous experience with them.
http://m.aliexpress.com/item/32518203168.html?tracelog=storedetail2mobilesitedetail
It's boost though.
I'd only ever run 1x so double compatibility not necessary
A bit over budget but I went for a Cotic Solaris. There's no way a 3.0 tyre is going in the back though. I've got a boost front end and 3.0. Am actually glad I've a 2.8 in the rear as is still grippy but rolls faster than I would expect
What about an on one parkwood plus?
I've been thinking about a parkwood but they're no lighter than my Swift and from memory they're reliant in a headset that seems to be fairly expensive. Plus I want to build it rigid and I'm not sure that'd work well on a parkwood
