6.8 kg road bike
[Closed] 6.8 kg road bike
Emondas have been on the pies since they were released then! Top model (SLR 10) was 4.6kg, for about £11k in 2014…
4.6 kg? I call BS. Top framesets generally 1.2 or 1.3 kilos, lightest wheels 1.2 kilos ish, group set at least 1 or 2 kilos, then finishing kit and pedals.
Posted : 18/06/2020 6:36 pm
Just regards the whole obsession with lightweight versus aero, or the quest to get both in some cases - the BMC Timemachine would be my bike of choice, and the answer to question a while back to if I had 5k to spend on a new road bike (plus another two more) .
BMC list weights on their website which is interesting. The base model Timemachine at 7k weighs about 9kg. The top end model, if you have about 11k, weighs 7.8 kg. But I know I’d rather carry that extra kg and ride a frame and bike with all that innovation, instead of just a pure weight weeny machine. But that’s just my view. Edit; I know these are well over 5k.
https://www.bmc-switzerland.com/timemachine-01-road-one-302033.html
Posted : 18/06/2020 6:47 pm
https://roadcyclinguk.com/gear/trek-emonda-slr-10.html
Posted : 18/06/2020 6:51 pm
It was definitely 4.6kg's, my LBS (a large Trek Dealer) had it on demo, we weighed. It was being sold a few years ago at a fair bit cheaper than the £11k, closer to £5k if I remember correctly, obviously thats second hand as it had been sent around the country to other Trek stores and used in various photo shoots.
Posted : 18/06/2020 7:38 pm
It looks like it would be good for that 100km uphill race in Taiwan but I can’t think what else really 😝😏🙈.
Posted : 18/06/2020 7:41 pm
and it finally arrived...
[url= https://live.staticflickr.com/65535/50336749498_0b60d80a1f.jp g" target="_blank">https://live.staticflickr.com/65535/50336749498_0b60d80a1f.jp g"/> [/img][/url][url= https://flic.kr/p/2jG5ZVm ]Orbea Orca[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
[url= https://live.staticflickr.com/65535/50337437826_a94a947686.jp g" target="_blank">https://live.staticflickr.com/65535/50337437826_a94a947686.jp g"/> [/img][/url][url= https://flic.kr/p/2jG9wx5 ]Orbea Orca[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
Posted : 13/09/2020 4:14 pm
Getting rid of those spacers under the stem will save you the 0.24kg required!
Posted : 13/09/2020 4:50 pm
Already done, although not cut the steerer yet. Bit of a PITA as I now need to shorten the front brake hose as there's 2" poking out the top end after lowering the stem!
I also took off the bonkers light SLR Carbino saddle (110g) and put on something a bit more sensible (300g).
Posted : 13/09/2020 4:55 pm
Is that 7.16 with pedals? If so that's damn light for a disk roadie.
Posted : 13/09/2020 5:02 pm
That's nice Ben. From Epic? Might get one of those... 👍
Posted : 13/09/2020 5:50 pm
Yeah took out some spacers from the wife's Liv aero bike. Then had to shorten pretty much all the cables and rebleed the brakes. She has etap now which was bit easier to fit.
Posted : 13/09/2020 5:56 pm
 beej
Prompted by this I weighed my Focus Izalco Max - with added eTap, Quarq power meter, pedals, cages, pump mount and garmin mount.
Bike
Weight
Which I'm quite happy with.
Posted : 13/09/2020 6:09 pm
You should be. That's farkin light but not aero disc so should be 👍
Posted : 13/09/2020 6:18 pm
Is that 7.16 with pedals? If so that’s damn light for a disk roadie.
Without.
From Epic?
From John Atkins Cycles in Leamington Spa.
Posted : 13/09/2020 7:06 pm
Still very light.
How does it ride then?
Posted : 13/09/2020 8:13 pm
Without.
Never quite understood why folks post weights of a bike without the pedals, you may as well remove the rear wheel and weigh it! Thats not a pop at you footflaps, so many folks do it.
Still under 7.5kg with pedals is bloody good for what looks like a fairly aero disk bike. Definitely lighter than my fairly high spec TCR and I'd say it looks better as well. What is it exactly and may I ask how much it was?
Posted : 13/09/2020 9:18 pm
Probably because the typical manufacturer's weights getting quoted elsewhere are all without pedals also, so most people's 'point of reference' is probably without pedals also.
Still fairly daft, by the same logic (contact points, rider preference) you might as well weigh without saddle also.
Posted : 13/09/2020 9:36 pm
Still very light.
Not ridden it yet, been fettling with gears and set up. Tyres / tubes / bottle cages etc should arrive today - which are the same as my other bikes (GP5000s + latex tubes) which will mean a more fair comparison.
Orbea Orca https://www.orbea.com/gb-en/bicycles/road/orca/cat/orca-m21eltd
£5399
Posted : 14/09/2020 9:54 am
When I see those quoted weights of the Edmonda it’s surprising how much weight discs are still adding to road bikes.
I would have thought system integration , Disc mounts, disc specific rims would have made the weight penalty fairly negligible now.
For comparison my rim braked 2016 Supersix Evo with Ultegra and Ksyriums is 7.3kg without any Gucci parts and owes me no more than £2k.
To get to that level now it seems you need to spend £5k ?
Posted : 14/09/2020 10:37 am
Not really, the top end frames from the big brands all come with a hefty price premium eg my Orca frame on its own is £2700 and it didn't cost any more to make than a Planet-x open mould carbon frame. It's probably a bit better, but you're really paying for the look / brand. Eg friend has just bought a £4k Colnalgo C64 frame and built it up into a £10k road bike - lools absolutely gorgeous, but it's not £5k better than my Orca nor £7k better than a Planet X generic etc.
Posted : 14/09/2020 10:45 am
It may never be equal. for example the difference in weight between an Ultegra disc vs rim caliper is 20grams. But with discs you need a Disc (100g each), heavier hubs that can run a disc (?g), heavier built forks (?g), maybe heavier built/spoked wheels.
Posted : 14/09/2020 11:00 am
Also there is still a price premium attached to discs, so not only are you paying more for (negligibly, admittedly) heavier components, but that additional cost is eating into the available budget for nice kit elsewhere, hence heavier kit specced elsewhere too!
Same argument for a lot of steel bikes I think, you're paying more for the steel frame, which is heavier, and now have less available budget for components elsewhere so end up with a heavier frame AND heavier parts.
Edit: and finally, since disc brakes will never win a weight argument, manufacturers are now pushing aero more, and aero is heavier, so you're more likely to see a heavier aero frameset, with heavier brakes and cheaper, heavier components. Triple whammy! 😉
Posted : 14/09/2020 11:04 am
Still very light.
Just taken it for a quick 50k spin.
It's stiff. Much stiffer than my CR1, can't tell if its the frame or the wheels, but accelerates quicker and more road vibration - although possibly I can reduce that with 5-10 psi lower pressure in the tyres. Not at all scientific but just PBed on my local 50k loop without really trying, just making an effort rather than beasting myself. Wheels are only 40mm deep compared with my 404s which are 58mm.
Posted : 14/09/2020 9:30 pm
Much stiffer than my CR1, can’t tell if its the frame or the wheels, but accelerates quicker and more road vibration
I went from a CR1 SL to a Boardman with a hi-mod frame this year. The new bike was described in reviews as being on the firm side (but very well priced).
Yes it was rattly with the 28c tyres at my normal 90psi-ish, but once I dropped them to 70-ish it was waaaay more comfy - and I'm sold on road tubeless after absent-mindedly hitting a square-edged pothole at speed, feeling the rims hit but didn't get a flat either end.
It's just over 1kg heavier, but faster everywhere so far.
Posted : 15/09/2020 9:36 am
I've a CR1 Pro and a CR1 SL. The pro is supposed to be the old Addict from yonks ago. The story was they'd stopped making the Addict and remarketed it as the Pro. It's a firm but comfy ride but not jiggly and I don't get sore on longer rides. I've also been riding the SL a lot recently including a couple of centuries. It's noticeably stiffer and harsher than the Pro. On the SL, I also get a stiff lower back on very long rides. One has Conti GP4000's the other Schwalbe One's - both 90psi front/95psi rear so very similar.
The SL weighs 7.2kg inc pedals/cages/mount, the Pro ~7.5kg. They're chalk and cheese but both lovely to ride 👍
Posted : 15/09/2020 9:52 am
I started at 60 psi front, 70 rear...
I’ve a CR1 Pro and a CR1 SL. The pro is supposed to be the old Addict from yonks ago
My CR1 Pro pre-dates the Addict it was Scotts top road race frame when I bought it.
Posted : 15/09/2020 10:11 am
It’s just over 1kg heavier, but faster everywhere so far.
But the weight !!!!!!! *
* I'm with you....weight is but a number and most of us posting here including those concerned about the bikes weight would likely see bigger gains from one less pie than the difference in weight between disks and calipers.
Glad the new bikes working out FF.
Also while it may look like a planet X open mould frame....you'd like to think the QC was better ....you might find the headtube on your orbea is perpendicular to the ground /rear axle.......
Posted : 15/09/2020 10:17 am
* I’m with you….weight is but a number and most of us posting here including those concerned about the bikes weight would likely see bigger gains from one less pie than the difference in weight between disks and calipers.
But is it at all conceivable that you could eat one less pie AND buy a lighter bike? Win-win! 😀
Also, as you eat fewer pies and get lighter, the bike starts to become a greater proportion of the overall 'system' weight, so the fewer pies you eat, the MORE you need a lighter bike.
Anyway, moving away from the theoretical and back to the real world. My 'light' bike is significantly more fun to ride than my 'heavy' bike. Difference in weight is 1.5kg. Perhaps it's psychological, but not only do I enjoy riding it more, I'm faster on it, and that's despite having cheaper heavier tyres on the light bike so that I can pop it on the rollers on wet days.
Until I'm competing and trying to shave seconds off my time I'll never be convinced of the merits of heavier bikes 😉
(oh and p.s. @trail_rat, thanks for helping me sell that saddle, it was much too heavy, I've found one 30g lighter 😉 )
Posted : 15/09/2020 11:03 am
it was much too heavy, I’ve found one 30g lighter
On the subject of light saddle, my Orca came with a 110g SLR saddle! Will stick it on Ebay as way too unpadded for my bony arse.....
https://www.selleitalia.com/en/saddles/slr-boost-kit-carbonio-superflow/
Posted : 15/09/2020 11:09 am
Ha talking of budget. I bought a Raleigh Criterium Elite during lockdown from the selling pages mainly to use on my turbo..
Quoted weight was 8.8kg with wired tires, a lead seatpost and a sofa of a saddle.
Cost £200.
Swapped out tyres for Ones, put in a carbon post, lighter but still cheap saddle and campag potenzza brakes rather then the heavy(and flexy) RSP ones, lighter QR skewers, lighter seat collar and a prime lightweight stem.
(and cleaned off about 3kg of grime and grease!)
Total weight now 7.9kg according to proper scales
Total cost £420.
Posted : 15/09/2020 11:37 am
I know the orbea isn't cheap, but I can't believe it comes with a 250 quid saddle! Wouldn't get that with a pinerello I'd bet.
Posted : 15/09/2020 12:12 pm
I know the orbea isn’t cheap, but I can’t believe it comes with a 250 quid saddle! Wouldn’t get that with a pinerello I’d bet.
I was very surprised, I guess it cost them a lot less, maybe Selle Italia promoting it by offering it cheap to premium bikes etc.
Posted : 15/09/2020 12:16 pm
Selle Italia are weird though, aftermarket prices are all over the shop too, wouldn't be surprised if they were 'dumping' a load of them somehow.
Posted : 15/09/2020 12:33 pm
 Joe
Footflaps - it looks really nice. You are tempting me.
Posted : 15/09/2020 12:55 pm
Quick question. I'm a luddite mountain biker so don't have a clue about road bikes..... they all seem crazy light to me after riding a 32lb mountain bike. Does an extra kilo or two really make a lot of difference on the road or does riding an ultra light bike feel a bit twitchy? Won't a bike that weighs a kilo more be a bit quicker down hills? Genuine question because I really can't imagine even noticing a kilo on a bike when they feel that light.
Posted : 15/09/2020 1:10 pm
An extra kilo or two on a road bike is huge. My aluminium bike is only about 700g heavier than my carbon one, and I can feel the weight difference on a climb. I guess some of this depends on the weight of the rider though (I'm pretty light)
Being quicker downhill on a road bike doesn't really matter a jot (unless you're racing :). Downhills are generally a tiny proportion of a road ride, and unless you are in the alps, they are over within 5 mins max. Whereas you might spend a couple of hours pedalling uphill...
Posted : 15/09/2020 1:37 pm
Once you get over a certain point it is significant, but I'm not so sure about 7kg vs 8kg.
What that certain point is depends on the individual, but I wouldn't really be happy with a 10kg+ road bike personally.
Posted : 15/09/2020 1:43 pm
Once you get over a certain point it is significant, but I’m not so sure about 7kg vs 8kg.
What that certain point is depends on the individual, but I wouldn’t really be happy with a 10kg+ road bike personally.
A Kilo is a Kilo, it makes a difference in the number of seconds it takes to TT an ascent but not one that is significant to the experience of an average rider - it isn't going to enable you to complete different riding routes or keep up with with different category of riders.
I remember last year this guy turned up to a UCI stage race with a sub 5kg bike. He had to tape a heavy hammer to his bike to get past the bike check for the TT on the first day.
On the 2nd day the hammer had disappeared, didn't stop him dropping off the back of the pelo on one of the first hills of the day, conversely my old 9kg bike didn't stop me from keeping in the group on the climbs.
Posted : 15/09/2020 2:01 pm
I went out the other week for 100k and forgot to take any bottles, defintely noticed it on the hills, the bike felt quite spritely!
Posted : 15/09/2020 2:11 pm
Anything under 8 kilos is a decent weight and you'll struggle to notice much difference over any ridden circuit. your bodyweight will fluctuate by about this much from ride to ride. As will the volume in your water bottles.
10 kilos is heavy, even with disks, 9 kilos is disk territory, 8 kilos is rim brakes and/or posh bits, 7 kilos is posh carbon frames and nicer bits, 6 kilos is not allowed in racing.
Posted : 15/09/2020 2:15 pm
Dunno where all of your bikes' pies are coming from - my aeroad, with 60mm clinchers, one-piece bar/stem and a mix of DA, eTap and a power meter is ~ 6.9kg with pedals, two bottle cages and a wahoo mount.
Posted : 16/09/2020 2:15 pm
Dunno where all of your bikes’ pies are coming from – my aeroad, with 60mm clinchers, one-piece bar/stem and a mix of DA, eTap and a power meter is ~ 6.9kg with pedals, two bottle cages and a wahoo mount
Interesting. Every review of the Aeroad, including the Canyon website, appears to gave a basic weight of over 7kg.
Posted : 16/09/2020 2:29 pm
Anything under 8 kilos is a decent weight and you’ll struggle to notice much difference over any ridden circuit. your bodyweight will fluctuate by about this much from ride to ride. As will the volume in your water bottles.
Think this might have been argued somewhere in the thread already, but why would the difference between 6kg and 8kg feel less significant than 8kg and 10kg? The former is proportionally a lot greater after all.
Posted : 16/09/2020 3:46 pm
If you add on the mass of the rider, the difference is very modest indeed; 80/78 compared with 78/76. It's all psychology. More likely it's the perception as one throws the bike around standing on the pedals in a climb.
Posted : 16/09/2020 4:02 pm
Yes it is mostly perception and the fact the bike just feels lighter. Do people really think they would feel faster if they went from 70kg to 69kg?
There are clearly limits though as a 15kg road bike would feel crap.
Posted : 16/09/2020 4:09 pm
Page 10 / 11
