can i use this as opposed to a 50mm stroke? i've heard it can be done to up the travel but can anyone confirm it? there used to be a thread on here about it but all the old threads got wiped out since the hack. i can't see it causing any problems UNLESS the rear wheel is going to foul the frame. Your opinions are appreciated!
Tim
Posted : 13/03/2009 6:04 pm
Yes you can use a 57mm stroke shock,i did on mine with no problems and more travel
Posted : 13/03/2009 6:07 pm
thanks erny i thought you could. so did it make much difference to your ride? and do you know how much extra travel you get?
Tim
Posted : 13/03/2009 6:27 pm
er i think it goes from 130mm to 143mm
Posted : 13/03/2009 8:52 pm
