55mm Chainline??
[Closed] 55mm Chainline??
[#11690062]
So my new frame coming (Slash) is 55mm chainline
Trying to understand if my current X01 cranks are going to fit.
presume these are standard 52mm (coming off Vitus Sommet)
I will run a 30T so gives more clearance.
55mm seems a rare breed??!!
Posted : 19/01/2021 11:08 am
55mm is achievable with raceface 30mm cranks using a different length spindle. There is a tech document on their site with the details linked from the crank models.
Posted : 19/01/2021 11:13 am
My understanding is that you just need a zero offset chainring. Your current chainring will be 3mm giving you a 52mm chainline. Therefore zero 0mm will give you 55mm.
Posted : 19/01/2021 11:28 am
ah yes - this makes sense, and hopefully don't need to order a new crank - cheers
Posted : 19/01/2021 11:39 am
I don't know about that particular bike, but as Davros says you can get different offset chainrings if you have a direct mount SRAM crankset.
I know Superstar do 0mm, 3mm or 6mm offset rings for SRAM - and one of those is likely to be correct. They have a 20% off deal at the mo as well.
Posted : 19/01/2021 11:42 am
yep just looking -
wolftooth and superstar. nice
Posted : 19/01/2021 11:47 am
Just be careful with crank clearance on the chain stay. Does it need a 55mm chainline because the back end is wide.
Some direct mount rings you can also flip the ring over two get a wider chainline.
Posted : 19/01/2021 11:51 am
yep just looking –
I've found the Superstar ones last really well, FWIW.
Posted : 19/01/2021 11:52 am
hmm good point - that is an important question nixie....
I suppose until I offer them will be hard to know
https://www.bike-discount.de/en/buy/truvativ-descendant-carbon-eagle-dub-12-speed-dm-crank-30t-55mm-874708
Seen these as a backup...
Posted : 19/01/2021 11:55 am
looking on the spec of the complete slash it comes with a
Size: M, M/L, L, XL
SRAM GX Eagle, DUB MTB Wide, 30T, Boost (55 mm chainline), 175 length
so as you say, maybe need it to clear the back end....
Posted : 19/01/2021 11:59 am
https://absoluteblack.cc/sram-oval-bb30.html
Interesting as here Absolute Black say a superboost crank with a 0 offset ring is 55mm chainline!??
Posted : 20/01/2021 10:48 am
