45650b max fork tra...
[Closed] 45650b max fork travel
[#6334391]
I am pretty sure I read somewhere that 456 evo2 can take 160mm forks. Since 45650b have same geometry, will it be fine with 160mm forks?
Posted : 12/07/2014 3:46 am
http://www.on-one.co.uk/i/q/FROO45650B/on-one-45650b-frame
On one say 100-150.
10mm of for travel will make a small difference, but it's also worth remembering that the axle to crown is important too. I have various forks in the garage with the same travel but all are different lengths. So if you have a long 160mm fork with will be exaggerated a lot more. Potentially you could end up with a 150mm fork that is longer than a 160mm fork.
Posted : 12/07/2014 4:04 am
I've seen it on one one website, but again, it says the same on 456 evo 2 frames . The forks would be dual position pike
Posted : 12/07/2014 4:08 am
Just measured top of the axle ro the top of the crown is 55cm. external bottom cup add another 10 mm
Posted : 12/07/2014 6:36 am
I think Brant normally uses Rockshox ac length and takes into account the on one headset. This was the case with el guapo.
Posted : 12/07/2014 7:02 am
456 refers to 4", 5", 6", so there's the answer. Official answer that is.
Posted : 12/07/2014 12:32 pm
this is Brant's reply from other forum regarding 160mm forks on 456 evo: 'The frame main tubes have been CEN tested to 160mm in previous model, so I imagine it's all fine. Geoemtry will be fine with longer fork. '
I've sent email to One One, but maybe someone can confirm it faster on here.
Thanks
Posted : 12/07/2014 1:05 pm
