Just building my 456 up, getting the wheel in the rear dropouts is proving difficult. I'm assuming I just need to sand a bit of paint off the inside of the dropouts?
Posted : 09/06/2010 9:51 pm
I had the same problem, i put the rear wheel in place then sat on the bike, that forced it in!
Posted : 09/06/2010 9:54 pm
cool, cheers. Apart from that little problem and not having enough outer gear cable for front and rear mechs the build is nearly done, it looks lovely!
Posted : 09/06/2010 9:57 pm
I had the same problem too. Took the paint off the inside of the dropouts and it fitted. Still a bit of a wrestle to get in/out though.
Posted : 09/06/2010 10:04 pm
same problem with mine gentle sanding solved the problem
Posted : 09/06/2010 10:06 pm
