456 Gear Cable rout...
[Closed] 456 Gear Cable routing.
[#3766017]
Quick Question, I've got a 456 frame coming.
Is it possible to run the Gear outter all the way through without braking?
Or do the Lugs need drilling out?
Posted : 12/03/2012 3:41 pm
Straight run all the way through both front and rear.
Posted : 12/03/2012 3:42 pm
Woo Hoo, thanks for the quick Reply.
I just called On one to ask. and they said it breaks!!! But when i looked at the pics on line i did wonder.
Hence my question here.
Posted : 12/03/2012 3:43 pm
Carbons do.
Steel ones don't.
I shall educate our CS team.
Posted : 12/03/2012 3:44 pm
oh i'm confussed now!
So on the new On one 456 Steel, Can i run an outer straight through?
Has anyone got close up pics of their set-up?
Posted : 12/03/2012 3:46 pm
On my steel 456, the rear outer cable runs in one piece from the shifter to the mech. Same with the front. You have to thread them through the cable guide/loops.
No pics tho. Hope that helps.
Posted : 12/03/2012 3:50 pm
Excellent, Thanks Skiprat 😀
Posted : 12/03/2012 3:52 pm
Sorry - I was referring to the "It breaks" comment.
Skiprat is quite right. The gear cables run through O guides. The disc brake has M clips.
Posted : 12/03/2012 3:53 pm
HaHa Cheers Brant.
Nice one, cheers guys.
Posted : 12/03/2012 3:58 pm
Carbons do.
Steel ones don't.
Oh man, I've just bought a C456, I don't want it to break. 😈 😀
Posted : 12/03/2012 7:24 pm
 igm
The gear cables have continuous outers on my carbon 456 - but I spent 5 minutes with a 4mm drill and a very small round file.
4.5mm might have been better in retrospect but you can always remove material later; you can't add it.
Posted : 12/03/2012 7:51 pm
