456 frame size - 16...
[Closed] 456 frame size - 16" or 18" for a 6' lass?
[#2764521]
My gf currently rides a 19.5" trek 'travesty'. It's horrendous, she's over stretched and at risk of injury via the top tube. Some muppet at Evans is responsible 😡
Do you think a 16" would be too small? She's got relatively long legs, and shorter reach, so I thought a 16" frame with long seat tube might be best. Unfortunately not going to have time to test ride one first.
M
Posted : 18/05/2011 10:14 am
measure her existing frame, decide what you need changed in terms of height/reach and compare with 456 sizing?
bear in mind that 456's woudl probably be run with a much shorter stem than her trek.
Posted : 18/05/2011 10:19 am
I'm 6ft, and ride an 18" frame. Pretty sure there's less than 2" of post (above the minimum line) in the frame.
Generaly, womens frames are; lighter, slightly shorter, flexier as they're lighter, slightly shorter torso and less strength.
456 is a good frame but heavy, very long and stiff, must be a better option?
Posted : 18/05/2011 10:20 am
Yep, do it from measurements, it's the best way.
FWIW I'm a leggy 6' and liked my 20".
Posted : 18/05/2011 10:23 am
I'm 6'1" and rode a medium steel 456 and also have a medium inbred plus a medium 456 carbon.
my 2p is that a medium would probably be ok with a non-layback post plus a shortish stem.
Posted : 18/05/2011 10:27 am
Thanks. Hadn't appreciated the 456 was particularly long - definitely not a good thing! Will maybe consider a standard inbred or similar.
Posted : 18/05/2011 10:33 am
inbred is pretty much the same size I think?
just slightly less beefy for shorter forks.
Posted : 18/05/2011 10:34 am
i think the inbred has the same ett for a given fork length. the 456 will appear shorter due to longer forks.
HTH
Posted : 18/05/2011 10:45 am
+1 inbred and 456 are same lengths
she'll be better on a 16 IMO. I'm 5'11" and I've got a 16 456 and have run a 18s in the past (456 and inbred). Not much in it but the smaller frame is more nimble and would suit your lass.
456 is burly. Unless she is a gnarly dudette then a std inbred would be lighter and enough.
Posted : 18/05/2011 10:54 am
I also thought the 456 & Inbred had pretty much the same geometry.
I'm 5'6 with 30" inside leg & use a heap of seat tube on my 16" Inbred.
I'd have thought someone 6' tall who you describe as leggy would be too tall for a 16" Inbred.
Perhaps 18" with a short stem would be the way to go?
Posted : 18/05/2011 10:56 am
Am just under 6" and ride an 18' 456 with a 10cm stem - inside leg is 32cms, so a 400mm seat post is close to it's tide mark - it's a high and stretched riding position, the way I like it for the riding I do on that bike.
Posted : 18/05/2011 11:02 am
My wife is 5'9" and has a 16" std inbred and I would say she is right on the limit for that size. I would say 18" for 6'.
Posted : 18/05/2011 11:04 am
Yeah.. I deffo wouldn't put a six footer on a sixteen inch 456 frame.. not unless they have some sort of crazysuper wierd arm/leg/torso ratio..
I'm 5'8 and have a lot of seatpost sticking out..
Posted : 18/05/2011 11:06 am
I'm 5'11" with short (29") legs and an 18" 456 is perfect. It's about a 70mm stem.
i'm 5'11" and ride an 18" 456.
have ridden 16s and they are just a bit too small. someone on here might be able to give you a test ride.
somthing canadian might have a shorter toptube.
Posted : 18/05/2011 11:08 am
Bez on here is 6' 4" and rides a 16" so maybe she should go 14"?
Posted : 18/05/2011 11:24 am
he does use a 600mm seatpost though.
Posted : 18/05/2011 11:25 am
wwaswas - Member
and a 150mm stem?? 😉
Posted : 18/05/2011 11:29 am
Typical bloke only thinking of himself!
Posted : 18/05/2011 12:59 pm
where are you/is she? Can you find someone with a 456 that she can try? If you/she is south london then email me if she wants to try out a small (I'm 5.11, inside leg is 31, sat on both a small and medium and could have got either to work I think, but went for the small with a longer stem and post)
Posted : 18/05/2011 1:48 pm
I also doubt a 456 or inbred is the best frame for her.
As said, they are all very long top tubes. The exception is the 14" really which does drop a bit and is perfect for smaller ladies.
I would be thinking Cotic Soul, Rock Lobster (Merlin) etc in 18/19" (whatever they come in) or if you are really set on a 456/inbred then the 18" with an inline seat post and short stem of 50-60mm.
Posted : 18/05/2011 2:13 pm
I'd suggest the 16 assuming she's typically lady proportioned (ie shorter torso / longer legs than a 6' bloke).
I ride an 18" and am 5'10, male and very short legged / long bodied, like to be stretched out (years of road riding before I converted) and the 18" fits just right with minimal layback post and a 90mm stem and I run a stiffly sprung 5.5" fork so that lifts the front to about its highest point/shortest top tube.
Or you could try an 18" with a very short stem (30-40mm) and an inline post if she's a bit less leggy (no offence intended).
Posted : 18/05/2011 2:18 pm
Re Andyl's post - my sister has a Merlin (Malt 1 or 2) and that fits her great (shorter top tube). Don't know if they still do them?
Posted : 18/05/2011 2:20 pm
I am 5'9 have a 15" Malt 2 and a 16" carbon 456.
The Malt frames have high BBs so a 15" is more like a normal 16".
I moved to a 456 as I was too cramped on the Malt with a layback post with seat all the way back and a 90mm stem.
I now run an inline post an 70mm stem on the 456 and it is perfect.
Given the choice I prefer long TT and short stem for more direct steering but I do have a typical long male torso. She will need a long seat post on a 16" 456 as I am guessing she will have at least 34" legs if not a couple of inches longer?
Posted : 18/05/2011 2:55 pm
My girlfriend rides a 16" inbred with a long seatpost, she is 5ft 10". Right on the limit I reckon. I would go 18" for a 6 footer.
Posted : 18/05/2011 3:53 pm
 lord
mowgli if your near lancashire your welcome to have a go on my inbred 16"
(bike)
Posted : 18/05/2011 5:45 pm
 Olly
im 6'5" and ride an 18" 456 no problems.
my trance ("marathon" bike) is a 21.5".
also, girlies tend to have shorter bodies in ratio to thier leggies than blokes i seem to recall, so unless its a lady specific frame, you want to choose one that's "too small in the leg" really.
Exeter if you want to try an 18" 456 summer season, a 20" inbred, or a 16" inbred 😉
Posted : 18/05/2011 6:09 pm
 br
tbh She'd be better trying a Ladies specific.
Posted : 18/05/2011 7:45 pm
